BGP and OSPFv2 Auto-peering are mutually exclusive. Only one form of
      Auto-peering can exist at a time.
  The following features are not supported in BGP auto-peering:
    - Stacking
    - AutoBGP LAG with Extended Edge
					Switching
    - Static LAG attachments to AutoBGP
    - AutoBGP links on Extended Edge
					Switching ports
    - MPLS, VPLS, L2VPN, L3VPN
    - PIM Snooping, PIM-SM, SSM mode
    - OSPF, OSPFv3, ISIS, RIP, RIPNG per VRF
    - IPv6 within VRF
    - VRF route leaking
    - EVPN multi-homing Ethernet segments
    - Explicit-remotes mode used for VNET flooding
    - AutoBGP MLAG
    - EVPN does not interoperate with third-party devices
  The following limitations apply:
    - Manual configuration of MLAG is supported. One MLAG peer per leaf
          node.
    - Loss of first multicast packet in the flow is expected due to slow path forwarding.
    - Static router must be an external router per VRF.
    - VLANS spanning multiple bridges, where each bridge is AutoBGP LAG connected, must be
     VXLAN-based, or AutoBGP LAG replaced with MLAG.
    - VLANs behind a bridge that is AutoBGP LAG connected and AutoBGP node has same VLAN
     ports must be VXLAN-based or AutoBGP LAG replaced with MLAG.
